mgholland
Aug 27, 2022Aspirant
Upgrading a ReadyNAS 204 to firmware 6
I purchased a used ReadyNAS RN204 and it is still showing Firmware - RAIDiator 5.3.13. When I try to check for updates it says it is currently running the latest firmware. If I try to manually ins...
- Aug 28, 2022
mgholland wrote:
That is what is weird. It came in the box as an RN204 and the serial number matches. in Dashboard it says RN204 but with the old firmware 5.3.13. I have no idea how he got that version on there. On the back of the NAS it shows FW:V6.3.2
That is weird. The memory also matches what's in the RN204 (2 GB).
You could try a USB recovery. Use the process for ARM that is described here:
Aug 27, 2022Guru - Experienced User
I think you must actually have a ReadyNAS NV+ v2. Those run 5.3.x firmware (with 5.3.13 being the final release). This cannot be upgraded to 6.x firmware (and the RN204 never ran 5.x, it was released with 6.x).
Does your NAS say "ReadyNAS NV+ v2" on the front panel? Note other labels are confusing.
