mgholland
Aug 27, 2022Aspirant
Upgrading a ReadyNAS 204 to firmware 6
I purchased a used ReadyNAS RN204 and it is still showing Firmware - RAIDiator 5.3.13. When I try to check for updates it says it is currently running the latest firmware. If I try to manually ins...
- Aug 28, 2022
mgholland wrote:
That is what is weird. It came in the box as an RN204 and the serial number matches. in Dashboard it says RN204 but with the old firmware 5.3.13. I have no idea how he got that version on there. On the back of the NAS it shows FW:V6.3.2
That is weird. The memory also matches what's in the RN204 (2 GB).
You could try a USB recovery. Use the process for ARM that is described here:
mgholland
Aug 28, 2022Aspirant
That is what is weird. It came in the box as an RN204 and the serial number matches. in Dashboard it says RN204 but with the old firmware 5.3.13. I have no idea how he got that version on there. On the back ov the NAS it shows FW:V6.3.2 so somehow he must have downgraded it. not sure if there is a way to sideload firmware on it or login to root to maybe try to update it.
mgholland
