rob-catron
May 03, 2017Aspirant
Upgrading an old ReadyNAS 3200
Greetings all, I have a situation. I have a 4 year old 24TB Readynas 3200 that is still super functional. Unfortunately, when I purcased, I only bought one extra WD 2TB Drive (WD2003FYYS) I...
Sandshark
May 03, 2017Sensei
The 3200 is a very slightly customized version of a Supermicro server running the Netgear software. Pretty much any enterprise grade drive should work on it (up to the limitations of the ports, which is 2TB on all but the first 4). With a 12-bay chassis, I would not suggest desktop or even NAS purposed drives. The ability to use advanced format drives does depend on at what OS version the last factory default was performed. I don't recall the critical version, but I'm sure one of the moderators will chime in.
Your 3200 can run OS6.x, too, if you so choose. It requires a factory default and won't lift the hardware limitation on drive sizes.
One thing I have wondered is if you can disable the RAID controller in the motherboard via the BIOS and install an LSI 9211-8i card, as is built into the 4200V2 and have the OS recognize it. That would get you past the 2TB limitation. You'd need the right cables, too, but it would be a lot cheaper than upgrading the whole machine (though no increase in speed).
- mdgm-ntgrMay 03, 2017NETGEAR Employee Retired
So long as you're running 4.2.12 (or later) you could replace the disks (one at a time) and get 4k sector partition alignment.
- rob-catronMay 04, 2017Aspirant
mdgm wrote:So long as you're running 4.2.12 (or later) you could replace the disks (one at a time) and get 4k sector partition alignment.
Thank you! I am running the latest 4.2.30 - so I should be good to add a modern 2TB drive, then, correct? Any suggestions?
I was looking at WD site, specifically their gold datacenter drive series (as Red's look to be 5400 RPM)
WD2005FBYZ 2TB SATA 6Gb s 7200 128MB https://www.wdc.com/products/business-internal-storage/wd-gold.html#WD2005FBYZ
- mdgm-ntgrMay 04, 2017NETGEAR Employee Retired
It will give you 4k sector partition alignment for the disk that is added. If a disk was added before 4.2.12 then it would not be 4k sector partition aligned unless after updating to 4.2.12 you removed it, then added it back again and waited for the resync to complete before moving onto the next disk.
Sandshark wrote:The 3200 is a very slightly customized version of a Supermicro server running the Netgear software. Pretty much any enterprise grade drive should work on it (up to the limitations of the ports, which is 2TB on all but the first 4).
That is what I figured - surely any comparable spec modern Enterprise drive would work. It would be nice if Netgear would maintain legacy unit's HCL list (especially when customers paid $6k+ for them back in the day), but I understand that legacy means legacy, lol
