Feb 07, 2016Tutor
Upgrading from ReadyNAS N102 to a 202
I'm thinking of replacing my N102 with a 202 and I would like to know if I can just remove my HDD's, 2 @ 3TB, from the N102 and install them in the 202. Do I need to worry about data loss? Th...
- Feb 08, 2016
Hi 1793,
Both are running on same architecture so it should be fine. Just ensure the RN202 unit runs the same 6.4.1 Firmware. It would be much better if you will backup all the important data before you move it to the new unit.
Kind regards,
BrianL
NETGEAR Community Team
Feb 07, 2016Guru - Experienced User
1793 wrote:
@I'm thinking of replacing my N102 with a 202 and I would like to know if I can just remove my HDD's, 2 @ 3TB, from the N102 and install them in the 202.
Thanks in advance
Do you mean an RN102??? what firmware is it running?
- 1793Feb 08, 2016Tutor
It is an RN102 with firmware 6.4.1
- BrianL2Feb 08, 2016NETGEAR Employee Retired
Hi 1793,
Kind regards,
BrianL
NETGEAR Community Team- 1793Feb 15, 2016Tutor
I was able to just move the HDD's over to the new ReadyNAS 202 from my ReadyNAS 102, one at a time and no issues.
Thank you for your help and input.
