Esoteric
Aug 02, 2021Tutor
Upgrading my readynas
I've had my ReadyNAS for ages.
I recently tried to swap out my drives to upgrade and it all failed. Luckily, there were some awesome people on here to help me out.
After fixing everything I want to expand my readyNAS with a 4tb drive. When I add the new drive it just mounts it as inactive. I looked through my product's instructions and it's so unclear... How do I upgrady an extra 4tb and still keep my existing data? It's all in RAID 5 right now.
I have attached a screen shot for reference.
It looks like the volume is inactive, which is not good.
I see two 4 TB drives - were you trying to install both? If so, did you wait for the resync to complete on the first one before you replaced the second?
- EsotericTutor
Hey StephenB !
Not sure if you remember but you recently helped me here: https://community.netgear.com/t5/ReadyNAS-Storage-Apps-Old-Legacy/Remove-inactive-volumes-after-hard-drive-upgrade-RN104/m-p/2121272#M16364They got all of it up and running again with the three disks that worked. (Don't worry, I have a back up of everything now too!)
This 4tb disk is the one where it failed to resync and caused all my problems. Do I need to format it or something? It was a blank hard drive. I'm just trying to expand my space in my RN104.
Thanks!
Looking again, the inactive volume is only disk 4. I am thinking it isn't actually blank - that it was formatted when you tried to add it before.
See if you can select that disk from the center graphic, and then reformat it.
