nandu
Oct 03, 2011Aspirant
Upgrading to Ultra 6+ from NV+
Hello all, I am considering upgrading my aging NV+ and NV units to a Pro 6 or Ultra 6+. I had some questions regarding my potential upgrade: 1) Is there any file size limitation on Time Machine ...
yoh-dah
Nov 14, 2011Guide
tenney wrote: 1) Is there any way to take my existing drives (and data!) and just plug them into either a Ultra 6 Plus or Pro 6 and poof everything is just moved over? Or will I need to have all new drives (at today's post-typhoon/flooding prices) in the new unit -- and then figure out how to copy everything over?
NV+ runs X-RAID which is a different format that X-RAID2 which is run on the Ultra/Pro platform. You will need to move the data across, perhaps using the NFS backup option between the two.
2) I'm seeing Ultra 6 vs Ultra 6 Plus price differential at US$150. Is it worth it for a bit faster cpu? It's unclear that the Pro differential is worth it for a SOHO of a dozen clients accessing the NAS, and almost never more than 2 at once. Any comments on how to contemplate Ultra Plus vs Pro?
The Ultra 6 Plus will have more transcoding power than Ultra 6. As mentioned above, Ultra 6 Plus can do 720p transcoding. Ultra 6 can do SD. This would be important if you're wanting to run Plex (see http://www.readynas.com/plex) a popular way of sharing video within and away from your home with mobile devices.
