eddy291
Jun 14, 2020Aspirant
upgrading using old disks NV+ to RN214
Hi, thanks for advice on upgrading and retaining old disks, I have a readyNAS NV+, so well over 10 years old. It runs fine but is showing its age and this obsolete tech has issues, as you will know...
- Jun 15, 2020
Welcome to the Community!
It is fine to use the old drives you have from the NV+ to your RN214 but the data needs to be backed up first since the drives will be reformatted once you migrate the drives to the RN214.
It is also possible to get the data accessible on the RN214 before formatting the drives but it will need intervention from Support. IMO, it would be best if you have a backup of your drive and start from scratch on the RN214 and transfer the data once setup is complete.
Straight migration is not possible since they have different OS.
HTH
Marc_V
Jun 15, 2020NETGEAR Employee Retired
HTH
eddy291
Jun 15, 2020Aspirant
Many thanks for a nice clear answer, I will start again
Eddy
