mlswayze
Jul 13, 2022Aspirant
UPS - Battery Backup / Installed New Batteries / How to clear "warning" message on Admin Page
I had some batteries start to fail on my UPS Battery Backup. I replaced the batteries inside UPS. How do I reset / clear the UPS warning message inside The Admin Panel (Radair)?
mlswayze
Jul 14, 2022Aspirant
Yes I removed the device, unplugged the UPS and re-installed.
The message is still there
Jul 14, 2022Guru - Experienced User
Have you tested the UPS?
Maybe connect it to a PC and install vendor tools (PowerChute, etc).
- SandsharkJul 14, 2022Sensei
It sounds like the UPS is still setting an alarm. Some (Eaton is one) have a battery timer that needs to be reset when it expires and you change the batteries.
