kwanm3
Jan 20, 2010Aspirant
UPS issue ReadyNas Duo IDialogplus Riello (IDP80)
Just bought a Riello iDialogplus IDP80 and connected to my Readynas Duo. However in Raidar and in Front view the Nas does not recognize that there is a UPS attached. It has the USB monitoring cable...
NewAngel
Jan 21, 2010Aspirant
Hi,
I'm searching to solve a similar problem but with an UPS IPEL/INFOSEC 1000 VA.
Idem not on compatibility list and not on icompatible list. My UPS is detected when I remove the USB cable. So I think we have a chance to make communicate UPS and DUO.
After search on web (a lot of hours), I've found DUO work with NUT software to monitoring UPS.
There's a compatability list of material support by NUT on http://www.networkupstools.org/compat/stable.html (RIELLO is not on, sorry...).
I've modified NUT's files (/etc/nut) to try to communicate with UPS, but I've a communicate error for each time.
In console mode, when I make :
nas:~# /etc/init.d/nut start
Starting Network UPS Tools: (upsdrvctl failed) upsmon.
I don't found info on upsdrvctl...
I've test some different driver but without result. By the past, I've uninstall NUTpackage and reinstall it with NUT-USB package, the list of drivers installed is more important but I don't f found the megatec driver (wich is for my UPS).
How install a specific driver on debian ?
Thanks for help
NewAngel
Thanks for help
NewAngel
