B52hbuff
Jul 16, 2011Aspirant
UPS Questions...
I am the proud owner of an Infrant ReadyNAS NV. It is currently connected to an APC ups and all seems to be fine. I see the warnings in the system log when the device detects power failure and power...
mdgm-ntgr
Jul 16, 2011NETGEAR Employee Retired
1. You need about a minute or two of runtime. Provided you're not overloading your UPS you should have this. I think it's generally recommended to not load the UPS with higher than a 80% load (if you put too much load on the UPS the battery will drain too quickly shortening its life, not to mention that you could overload your UPS by mistake)
2. Shutting down the NAS, I think takes less than a minute. Of course you should allow a bit of extra time just in case more is necessary.
3. If the NAS power cable is not both connected to a UPS and using UPS monitoring, then the NAS will shutdown unsafely which would be akin to holding in the power button till the NAS turns off to force a power off (not just initiating a power off, but bypassing the shutdown script and shutting down unsafely). This is not recommended. On the other hand,If the NAS's power is connected to the UPS and is using UPS monitoring then the NAS will shutdown safely when the shutdown threshold is met, which would effectively be pretty much like shutting down the NAS safely manually.
4. Connect the power cables for both units to the UPS. You can choose which NAS you use to monitor the UPS, but it would make sense to choose the Pro. You can use the network monitor feature, but do note you need to have the power for your router/switch connected to the UPS as well (routers and switches use little power and you can leave these to shutdown when the UPS battery runs out) so that the devices can communicate over your network when the power is out.
If you like you can even share the UPS with a PC. See Using the ReadyNAS to create a Network UPS for PCs
