B52hbuff
Jul 16, 2011Aspirant
UPS Questions...
I am the proud owner of an Infrant ReadyNAS NV. It is currently connected to an APC ups and all seems to be fine. I see the warnings in the system log when the device detects power failure and power...
markwoll
Aug 31, 2011Guide
Also be sure and test the UPS battery.
I have an APC that looked just fine to the readynas, fail when the power dropped.
It was good enough to stay down when the power came back up as I was not around at the time.
It took a while to fsck and resync the drives.
A new battery with higher amperage ratings will be periodically tested.
A Batteries Plus store is a good resource to have handy.
mark
mark
