cleveland_rocks
Dec 08, 2015Aspirant
USB 2.0 External RAID Not Recognized by RN314 with OS 6.2.0
Hi Everyone, I recently purchased a new ReadyNAS 314 running OS 6.2.0. Everything has worked great with only one technical problem. I'm using an old external Iomega RAID enclosure for as a backup...
- Dec 09, 2015
The NAS sees a Seagate ST3750840AS drive attached with no partition table, which I assume is your iomega drive. Currently we don't support external drives without a partition table, but we will support it in our next firmware release.
BrianL2
Dec 08, 2015NETGEAR Employee Retired
Hi cleveland_rocks,
It should mount just fine. Perhaps try the latest Firmware 6.4.1 and see if there's a difference. If the issue persists, extract the device logs while it's plugged in and send it.
Kind regards,
BrianL
NETGEAR Community Team
- cleveland_rocksDec 09, 2015AspirantBrian, Thanks for your response. The firmware update did not get my RN314 to recognize the external RAID. I'm sending you my log files. Hope that helps. ***
- BrianL2Dec 09, 2015NETGEAR Employee Retired
Hi cleveland_rocks,
Thanks for your feedback. Once the logs were sent, I let you know what I find.
Kind regards,
BrianL
NETGEAR Community Team- SkywalkerDec 09, 2015NETGEAR Expert
