cleveland_rocks
Dec 08, 2015Aspirant
USB 2.0 External RAID Not Recognized by RN314 with OS 6.2.0
Hi Everyone, I recently purchased a new ReadyNAS 314 running OS 6.2.0. Everything has worked great with only one technical problem. I'm using an old external Iomega RAID enclosure for as a backup...
- Dec 09, 2015
The NAS sees a Seagate ST3750840AS drive attached with no partition table, which I assume is your iomega drive. Currently we don't support external drives without a partition table, but we will support it in our next firmware release.
BrianL2
Dec 08, 2015NETGEAR Employee Retired
Hi cleveland_rocks,
It should mount just fine. Perhaps try the latest Firmware 6.4.1 and see if there's a difference. If the issue persists, extract the device logs while it's plugged in and send it.
Kind regards,
BrianL
NETGEAR Community Team
cleveland_rocks
Dec 09, 2015Aspirant
Brian, Thanks for your response. The firmware update did not get my RN314 to recognize the external RAID. I'm sending you my log files. Hope that helps. ***
- BrianL2Dec 09, 2015NETGEAR Employee Retired
Hi cleveland_rocks,
Thanks for your feedback. Once the logs were sent, I let you know what I find.
Kind regards,
BrianL
NETGEAR Community Team- SkywalkerDec 09, 2015NETGEAR Expert
- cleveland_rocksDec 10, 2015Aspirant
Yes, that's one of the Seagate drives in the external Iomega box. I actually have two 750 GB drives in a RAID 0 configuration. When I used Gparted to reformat the striped array to ext4, I must not have created a GPT; I'll try that and post how it works.
Thanks for the help. May the force be with you Skywalker.
