janforman
Oct 20, 2012Aspirant
USB EXT2/3/4 format from Frontview on ARM
It's possible to add ext2/3 format for USB devices via Frontend? Today I must use SSH access and mkfs on NAS or another Linux box. -- i don't need any help, this is for information only -- Btw. e...
Oct 23, 2012Guru - Experienced User
It would be nice if the user could set the rsync time-window to 1 second on the backup job. Granted this should not be the default, since it is possible for file to be modified twice within a second. However, if the backups are generally done off-hours, then the odds are pretty small.
JohnnyB wrote: ext2/3 uses a timestamp resolution of only 1 second while ext4 usees 1 nanosecond. Thus, incremental backups from ext4 to ext2/3 will not be incremental since the files on the target will (almost) always be older. E.g., see viewtopic.php?f=31&t=65736
