janforman
Oct 20, 2012Aspirant
USB EXT2/3/4 format from Frontview on ARM
It's possible to add ext2/3 format for USB devices via Frontend? Today I must use SSH access and mkfs on NAS or another Linux box. -- i don't need any help, this is for information only -- Btw. e...
Oct 23, 2012Guru - Experienced User
Yes.
mdgm wrote:
JohnnyB wrote: I do not understand why but rsync seems to work anyway: viewtopic.php?f=31&t=66167
Rsync copies the changes to files across. It's a protocol designed for backups particularly over the WAN (internet).
Though I believe that the normal settings on the ReadyNAS tell rsync to ignore analyzing files if the timestamp, etc matches, correct?
So without the "--modify-window=1" option, rsync would have to analyze every single file for changes, which will use a lot of computation and take more time.
At least that is how it looks to me. Unless rsync is smart enough to do this on its own if the source is running ext4 and the sink is running ext3???
