aalexandrebeta
Feb 27, 2017Master
USB recomandations
This should be interresting to have clearer recommandations on the HDD, type of partition and so on just to save users time and NG's!
FramerV
Mar 05, 2017NETGEAR Employee Retired
Hi aalexandrebeta,
Unfortunately there is no official release of compatible USB drives for the the ReadyNAS. Such a list would be difficult to administer, and keep updated.
This was stated on ReadyNAS OS 6: USB Port use.
aalexandrebeta
Mar 05, 2017Master
Brwosing topics on this community makes me think that there is a lack of precise and clear recommendations on that matter.
Often WD and SG casing use a proprietary program and their own way to configure witch disturb NG a bit. On the contrary generic equipment do not have those issues. When people have 2, 3 partitions on their drives it messes it a bit!
I am a bit a pain in the botom but having to deal with parents and relatives a bit grumpy they need a procedure!
So clear steps and precise instruction would avoid some mess!!
Regards!
- FramerVMar 06, 2017NETGEAR Employee Retired
Hi aalexandrebeta,
You have some good points there, if you have not done so; it might be best if you can also post this on our Idea Exchange for ReadyNAS.
Regards,- aalexandrebetaMar 06, 2017Master
FramerVyou wanted it so be it :)!
https://community.netgear.com/t5/Idea-Exchange-for-ReadyNAS/USB-recomandations/idi-p/1242546#M872
Regards.
