msd
Jun 29, 2012Luminary
USB3 Removed with latest Firmware - Seriously!
I couldn't believe my eyes when I read the "Last" line of limitations of Firmware RAIDiator 4.2.21 (x86) update released 13 June 2012 http://www.readynas.com/?p=6469 "The USB 3.0 ports on the Ultr...
msd
Jul 14, 2012Luminary
mdgm wrote: You can downgrade from 4.2.21 to 4.2.19. So I see no reason why you shouldn't give the update a try if you need what's been added in 4.2.20 and/or 4.2.21
Thats a good point I stand corrected about downgrading.....................as it only relates to those using 4.2.15 or earlier.
My main concern was obviously my initial "Post" about it "removing the USB3 capability. I see that statment has since been removed from the noted upgrade "Limitations". I suspect was "as chirpa noted" should not have been advertised as a potential "limitation"
If I get a chance to compare speeds "Before and After" update I'll report back.
