epeleg
Oct 21, 2020Tutor
UTF8 with NFS & Windows 10 on ReadyNAS Ultra 6 Plus with 4.2.31 Firmware
Hi, I had a Hard drive die and basicly ended up getting a new computer with new windows professional installed. When I tries to connect to my NAS shares using: Net use x: \\ip_addr\share as I wa...
Oct 21, 2020Guru - Experienced User
epeleg wrote:
Though it is possibly to install SMB1 back the linked document recommends agianst it.
NFS isn't any more secure than SMB1 (unless you use Kerberos, which the NAS doesn't do). So personally I'd just enable SMB1 on the Win10 PC.
Another option is to convert the NAS to run OS-6, which would give you current SMB.
