Jasonbree
Oct 23, 2012Aspirant
Utlra 2+ How to recover data
I have an Ultra 2+ that appears to have died. When powered up there is no link on either NIC and no activity on either hard disc. The fan runs and slows down after power up as expected. I am going ...
PapaBear1
Oct 24, 2012Apprentice
Sign onto Newegg. At the bottom of the web page click on the link to order history. It by default lists the last 30 days, but you can change that, and go back years. They only problem is that while they list the invoice number in the header bar for each order, when you expand to show the details, it is just the order not the invoice, but it may be sufficient. If you registered your unit when you bought it, you should not have to provide the receipt.
I maintain an archive of all my Newegg and other store e-mailed invoices and it goes back over 5 years now. That and all my other data is on the ReadyNAS by the way, and it is backed up automatically every night to a second ReadyNAS. It took me years to get into that position, but it is something I highly recommend.
