BrianLidd
Sep 09, 2014Aspirant
Viewing Files on Readnynas HD's in Linux?
I'm trying to recover data from a ReadyNas Duo crash. It seems that I've got one healthy drive and one dead one. With much help from the excellent people on this forum, I've succeeded in mounting t...
Sep 09, 2014Guru - Experienced User
use linux reader (http://www.diskinternals.com/linux-reader/). If its an older duo, you need to recover from disk 1.
If its disk 2, then insert the drive into the duo (by itself, with the duo powered down) and power on.
You are browsing the OS partition, you need to access \c\ which is a lvm volume.
- Aug 22, 2020Retired_Member
