chyzm
Jan 23, 2019Aspirant
Volume degraded after firmware update to 6.9.5 on RN212
NAS device was upgraded to the 6.9.5 version this evening and after reboot my drive in slot 1 is now showing as degraded. I rebooted and have power reset with no fix. Ran disk tests also with no luck...
chyzm
Jan 24, 2019Aspirant
Thanks for the info!
JohnCM_S
Jan 24, 2019NETGEAR Employee Retired
Hi chyzm,
You may upload the logs to a file sharing site then PM me the download link.
- chyzmJan 24, 2019AspirantOnce I get home I will get you those. Thanks!
- JohnCM_SJan 25, 2019NETGEAR Employee Retired
Hi chyzm,
I have checked the logs and see communication error with the drives. Most likely it is already an issue with the bay itself but it should not be related to the firmware upgrade specifically.
It will be best to contact support so they can process an RMA for the chassis.
Regards, - chyzmJan 25, 2019AspirantThank you!!!
