acng's avatar
acng
volume degraded
Hi,
I took over our ReadyNAS environment and one ReadyNAS is in degraded state.It's configured in RAID 6.
First such error was: "Volume: volume data health changed from Redundant to Degraded"
it's followed by numerous "Volume: volume data is Degraded."
When I go to System > Volume, it shows all drives are green and when I mouse over each one of them, they all say ONLINE.
I downloaded the logs and found in mdstat.log:
/dev/md/data-0:
        Version : 1.2
  Creation Time : Thu Nov 19 22:47:03 2015
     Raid Level : raid6
     Array Size : 39021667840 (37213.96 GiB 39958.19 GB)
  Used Dev Size : 3902166784 (3721.40 GiB 3995.82 GB)
   Raid Devices : 12
  Total Devices : 12
    Persistence : Superblock is persistent
    Update Time : Tue Mar 20 14:33:49 2018
          State : clean, degraded
 Active Devices : 11
Working Devices : 11
 Failed Devices : 1
  Spare Devices : 0
         Layout : left-symmetric
     Chunk Size : 64K
           Name : 43f68b06:data-0  (local to host 43f68b06)
           UUID : e92dd329:1a6ad005:49d51ef6:3035aab6
         Events : 2419044
    Number   Major   Minor   RaidDevice State
       0       8        3        0      active sync   /dev/sda3
       1       8       35        1      active sync   /dev/sdc3
      12       8       19        2      active sync   /dev/sdb3
       3       8       51        3      active sync   /dev/sdd3
       4       8       67        4      active sync   /dev/sde3
       5       8       83        5      active sync   /dev/sdf3
       6       8      115        6      active sync   /dev/sdh3
       7       8       99        7      active sync   /dev/sdg3
       8       8      131        8      active sync   /dev/sdi3
       9       8      147        9      active sync   /dev/sdj3
      10       8      179       10      active sync   /dev/sdl3
      22       0        0       22      removed
      11       8      195        -      faulty   /dev/sdm3
My questions are:
1. What exactly is the issue here? partition sdm3 is corrupted? How to fix this kind of errors?
2. I have no idea how long this ReadyNAS has been arouond. Is it something I can buy a drive and replace it? I registered the product and it requires purchase date but I don't have that info. How do I know it's under warranty or not?
thanks,
  • StephenB's avatar
    What do you see in disk_info.log and smart_history.log for that disk?
    • acng's avatar
      acng
      Hi,
      I don't see anything unusual for sdm in the disk_info.log:
      Device:             sdm
      Controller:         0
      Channel:            3
      Model:              WDC WD4000F9YZ-09N20L1
      Serial:             WD-WCC5D0HH7DHH
      Firmware:           01.01A02
      Class:              SATA
      RPM:                7200
      Sectors:            7814037168
      Pool:               data
      PoolType:           RAID 6
      PoolState:          3
      PoolHostId:         43f68b06
      Health data
        ATA Error Count:                0
        Reallocated Sectors:            0
        Reallocation Events:            0
        Spin Retry Count:               0
        Current Pending Sector Count:   0
        Uncorrectable Sector Count:     0
        Temperature:                    41
        Start/Stop Count:               7
        Power-On Hours:                 16538
        Power Cycle Count:              7
        Load Cycle Count:               4
      and no error in smart_history.log:
      model                 serial                realloc_sect  realloc_evnt  spin_retry_cnt  ioedc       cmd_timeouts  pending_sect  uncorrectable_err  ata_errors  timestamp   time
      WDC WD4000F9YZ-09N20  WD-WCC5D0HH7DHH       0             0             0               -1          -1            0             0                  0           1448002169  2015-11-20 06:49:29
      However, there have been bunch of errors for sdm in messages.log file.
      I have a tough time attaching the messages.log file. Tried messages.log, messages.txt, and even converted to pdf. Will try attach again after this post.
      Please advise. Thanks,
      • acng's avatar
        acng
        Please see attached.
ProSupport for Business
