Miplo90
Mar 02, 2013Aspirant
Volume scan found and corrected errors...almost every day???
Hello, I have a ReadyNAS Duo V2 with 2 hard drives: WDC WD30EZRX-00DC0B0 3TB in a RAID 1 configuration. If I have do a volume scan of the disks (Shutdown ->Next startup a volume scan) I get almost...
brinzlee
Apr 12, 2013Aspirant
Hi Pimm
Sorry to hear that.....they did the same for me and asked me to return the unit. I received a new unit fairly quickly, of course plus additional postage to me...and that didn't fix the fault.
I think their is a firmware fault on the NAS (5.3.7) itself so maybe hang on a little......I'm sure your fault is identical to mine....are you using XRAID2 with your Western Digital WD30EFRX
What was the version of BIN file they sent you to remedy the situation.
I have just been sent another version and installed it and so far so good, no inode errors anyway!!....Maybe they are waiting for my feedback before they release it
Regards
Brinzlee
Regards
Brinzlee
