Miplo90
Mar 02, 2013Aspirant
Volume scan found and corrected errors...almost every day???
Hello, I have a ReadyNAS Duo V2 with 2 hard drives: WDC WD30EZRX-00DC0B0 3TB in a RAID 1 configuration. If I have do a volume scan of the disks (Shutdown ->Next startup a volume scan) I get almost...
brinzlee
Apr 16, 2013Aspirant
Hi Pimm
Thats a shame.......although as I mentioned earlier its the same thing that happened to me
Would you like me to send you the firmware update they sent me.....I think it has fixed my issue....It might be worth a try.....you install it like an addon
Brinzlee
Brinzlee
