metmike
Nov 02, 2020Aspirant
Volumes gone after re-start after ReadyCLOUD setup RN102
Hi! My RN102 is always up and running. Mainly just sharing my Music Library to my SONOS sound system. I also save our family photos on the RN102. Sometimes I use the ReadyCLOUD function to share p...
metmike
Sandshark wrote:Is the NAS set up using RAID1 (via XRAID or otherwise)? If so, try booting with just drive 2, since it seems to only be complaining about drive 1 (which may be keeping it from seeing drive 2 properly).
FWIW, I suspect what you did before the reboot was not the cause. Something else was likely wrong with the volume that only showed up when you rebooted.
No, didn't work.
Nov 03, 2020Guru - Experienced User
If you don't have a backup of the files, then I recommend using paid netgear support (my.netgear.com) for this.
Another option is to set up the NAS from scratch and restore the files from backup. But if you do that, you should first download the full log zip file, and look for disk errors.
