mvee
Jan 27, 2017Aspirant
Warning: V+12 voltage in enclosure Internal is out of spec. (10.77 V).
Hello, I have a ReadyNAS 314. I started getting the voltage warning persistently. Online serach indicated need for firmware update. I updated to Firmware V 6.6.1 and the system rebooted in the update process.
The warnings haven't stopped. They still persist. Any solutions? Thanks.
MVEE
If you purchased new, then you are still covered by the hardware warranty (5 years). I suggest you contact support at my.netgear.com.
Note that if you purchased between 1 June 2014 and 31 May 2016 you also have lifetime chat support, so that might be a good way to begin.
- mveeAspirant
Thank you. I contacted chat support and they asked me for system logs and said they'll get back in 48-72 hrs. Hopefully it will lead to quick resolution.
