nixlimited
Apr 15, 2011Aspirant
Warning: WD20EADS Unreliable
I know that the WD 2TB EADS drive is listed on the compatibility list, but after just having multiple simultaneous drive failures with 3 month old drives I would caution anyone against using these. I ...
mdgm-ntgr
Apr 18, 2011NETGEAR Employee Retired
merc4a2, your running a very different NAS. For one thing NetGear recommends enterprise disks for rackmount devices not cheap green disks. The WD20EADS is not on the compatibility list for the 1100. The 1100 is a Sparc ReadyNAS and so runs different firmware to the Ultra.
What version of RAIDiator firmware are you running on your 1100 and if you got SMART errors before the disk failures what were they?
