nixlimited
Apr 15, 2011Aspirant
Warning: WD20EADS Unreliable
I know that the WD 2TB EADS drive is listed on the compatibility list, but after just having multiple simultaneous drive failures with 3 month old drives I would caution anyone against using these. I ...
akeiler
Apr 19, 2011Aspirant
Question to OP: As the 20EADS are "green drives", did you set the IDLE timer and the TLER function of the discs to a more "RAID compatible" level? If not certain SMART counters will skyrocket (e.g. Load Cycle Count) and you probaly end up killing your discs involuntarily.
