nixlimited
Apr 15, 2011Aspirant
Warning: WD20EADS Unreliable
I know that the WD 2TB EADS drive is listed on the compatibility list, but after just having multiple simultaneous drive failures with 3 month old drives I would caution anyone against using these. I ...
Nyarlathotep
Apr 24, 2011Aspirant
Yes, run the WD utility and use WDIDLE /D; that will disable the head parking. The heads on my drives parked thousands of times in three days of use.
