nixlimited
Apr 15, 2011Aspirant
Warning: WD20EADS Unreliable
I know that the WD 2TB EADS drive is listed on the compatibility list, but after just having multiple simultaneous drive failures with 3 month old drives I would caution anyone against using these. I ...
akeiler
Apr 28, 2011Aspirant
nixlimited wrote: @akeiler: I did not, and I am not sure how I would do that. Is that something enabled by jumpers on the drive, or is it through the Frontview interface? I would be interested to know. Anyway, my RMA drives have arrived and I am getting ready to rebuild the array, however I am mixing in some seagate drives as well. I will not rely on all WD drives again, at least not in this class. Notably, none of my drives failed SMART tests even though they failed the WD diagnostic test for too many bad sectors. Also notable, all of my drives failed right at the 4 month mark, which is similar to other posters.
Well, BigBearf already summed it up nicely (I was away a bit, so I couldn't answer earlier) - but essentially that's what I did as well. Using (I think two) DOS utilities from WD packed on a Universal Boot CD I applied both settings to my six green drives and they are running smoothly ever since.
