nixlimited's avatar
nixlimited
Warning: WD20EADS Unreliable
I know that the WD 2TB EADS drive is listed on the compatibility list, but after just having multiple simultaneous drive failures with 3 month old drives I would caution anyone against using these. I lost my entire array and have to start over.
Edit: The EARS model is now approved for use. I have no idea if it more reliable though.
  • I've been using 6 WD20EADS drives since August 2010. I did set the IDLE timer and the TLER function. Recently my Readynas Pro froze and started to become periodically unresponsive over the course of months. Very recently The admin panel stopped being responsive and I swapped out the Readynas as it was under warranty. When I got a new Readynas, two drives immediately showed up as bad. Testing reveals they at least have bad sectors. Swapping them out under warranty.
    The larger issue here is that I am down for days, have to do diagnostic work, lost the entire array and the whole system has effectively defeated the purpose of this backup device. More concerning is that the Readynas failed, the new one was immediately responsive and the old one did not catch the drive errors. Anyone have a method to pro-actively find bad sectors and imminent drive failure with these drives? I realize that an option is to drop the drives entirely and RE4 drives or equivalent but given the investment I'd like to avoid that course of action at present (I may end up having to go that way in the end for a simple, reliable setup).
    Presently, the only thing I have come up with is to do an offline "Test Disks" event at the boot menu on a recurring basis (perhaps monthly on a reminder) but I would prefer a more automated method with notifications.
  • I tried several utilities and found over the course of using the WD20EADS about a year or so that I'd have failures or errors on at least one drive every month or so. I upgraded to the Ultra 4+ and had more failures and finally got Seagate Caviar Black drives 2 years ago and never had another issue since. A friend had similar problems with the WD20EADS on a Synology device I believe. The extra cost of the drives more than offset the lost time trying to keep the WD's stable, not to mention the peace of mind.
ProSupport for Business
