Skywatcher
Jul 10, 2012Aspirant
WD introduces new, NAS-Specific Hard Drive line
Western Digital has announced a new hard drive line, specifically for NAS use with 1, 2 and 3TB capacities. The new WD RED line ( http://wdc.com/en/products/products.aspx?id=810 ) has been develope...
Sep 01, 2012Guru - Experienced User
Very true. Though updates to the v1 lists don't appear to be a priority for Netgear. So not being on the list for the v1 doesn't necessarily mean it won't work.
mdgm wrote: Those two products are very different. Compatibility with Duo v2 tells you nothing about compatibility with the v1 and vice versa.
Using drives that aren't on the HCL will likely result in loss of on-line support though, so I wouldn't move off the HCL without a good reason. I'd pass on the Caviar Greens at this point though, I think you'd be better off taking a risk on the new Reds than going with them.
