johnaduk
Sep 11, 2012Aspirant
WD My Book Essential 3TB USB 3.0 and NV+ v2
I naively bought a WD My Book Essential 3TB USB 3.0 (USB 2.0 compatible) for use as a backup drive for my NV+ v2 (with 3 x 3TB WD drives inside), having used a number of different USB 2.0 drives in th...
Zaim
Apr 06, 2013Aspirant
dsm1212 wrote: Yes it appears the filesystem on the 3TB is not readable by the readynas. Not sure why. Maybe these are the Apple versions of the MyBook? Regardless if you put something it understands on there it should show up then. If you have ssh access you could format it from the readynas. I'd use "mkfs.ext4 -m 0 /dev/sd<whatever>". There is a problem with timestamps backing up to ext3 USB drives from your main /c storage but it works great if you use ext4. NTFS formatted from windows will work but ntfs uses more cpu on the nas from what I've seen.
This doesn't work, at least for me, I can see the drive and all the data when I access it using my pc, but I can't read or write to it, DLNA doesn't work on it either.
Seem's stupid to me, why don't the drives work, really am disappointed with netgear at the moment, So many issue's, no fix's
