johnaduk
Sep 11, 2012Aspirant
WD My Book Essential 3TB USB 3.0 and NV+ v2
I naively bought a WD My Book Essential 3TB USB 3.0 (USB 2.0 compatible) for use as a backup drive for my NV+ v2 (with 3 x 3TB WD drives inside), having used a number of different USB 2.0 drives in th...
Apr 08, 2013Guru - Experienced User
You could try reformatting it as 2 NTFS partitions (using MBR, not GPT) and see if that works.
