RaptorMax
Nov 22, 2017Aspirant
WD RED 2TB do not sync with older WD Green 2TB on RNDU 2120
I have a RNDU 2120 (ReadyNAS Ultra 2) with 2x2TB. It came populated with 2x2TB WD green HDD (WDC WD20EARS-00MVWB0) Firmware RAIDiator 4.2.31 and 1024 MB memory After some years the hard disk drive N...
Docsavage123
Nov 25, 2017Aspirant
Check firmware on Nas box I had to downgrade mine to version before on my readynaspro 6 as it would not rebuild onto the disk. Reboot the Nas with just the WD green in it and add the WD red after. It should then start to rebuild. If the source disk is degraded that will need replacing as well
- StephenBNov 25, 2017Guru - Experienced User
Docsavage123 wrote:
Check firmware on Nas box I had to downgrade mine to version before on my readynaspro 6 as it would not rebuild onto the disk. Reboot the Nas with just the WD green in it and add the WD red after. It should then start to rebuild. If the source disk is degraded that will need replacing as wellI don't recommend downgrading firmware, that shouldn't be needed. I'd have thought that if there were an issue with resync on 4.2.31 we'd have seen many posts on that here by now.
The OP already followed the rest of your advice, so I think the next step is to test the new disk (since it might simply have failed).
