weinelm
Jul 23, 2016Tutor
WD Red 8TB WD80EFZX working on ReadyNAS Ultra 2
Hi, just to let anyone who is interested know, I upgraded the disks in my Ultra 2 to 2x WD Red 8TB. I'm running OS 6.5.0. The array resynced and the volume expanded to 8TB as expected. Seems to be wo...
weinelm
Jul 25, 2016Tutor
Yes it is the seek noise that's very noticeable. Previously with the Seagate drives I had to check the light to see if the drive was doing something, now I can easily hear it "ticking" away.
Jul 25, 2016Guru - Experienced User
The seek noise is 3 db louder than the Seagates, but I am wondering if the real issue is the delta between idle and seek. With the seagates, the noise spec is pretty constant (really no change between idle and seek), but there is a 9 db increase in the WD80EFRX between idle and seek noise.
Either way, if it bothers you, moving the NAS is likely the simplest solution.
