fastfwd
Oct 14, 2013Virtuoso
WD Red drives park their heads like WD Green drives?
So I checked the SMART stats on my new 4TB Red drive (WD40EFRX) today. Imagine my surprise when I discovered that in only 249 power-on hours it has already experienced 36820 load/unload cycles! Me...
May 03, 2014Guru - Experienced User
All you need to do is look at the SMART stats. Download the logs, and then download them again a day later, and compare the load cycle counts in disk_info.log
But letsgowithbob should be fine - he'd have seen much higher counts if he had installed drives which had the too-short threshold.
