fastfwd
Oct 14, 2013Virtuoso
WD Red drives park their heads like WD Green drives?
So I checked the SMART stats on my new 4TB Red drive (WD40EFRX) today. Imagine my surprise when I discovered that in only 249 power-on hours it has already experienced 36820 load/unload cycles! Me...
Jun 18, 2014Guru - Experienced User
The numbers look normal to me. It looks like you have disk spindown enabled. If so, what threshold are you using?
Is there something in particular you are concerned about?
