bachtech
Jun 09, 2017Aspirant
WD Red Pro WD2002FFSX 2TB on ReadyNAS 3200
I have a client with a ReadyNAS 3200 v1 running RAIDiator 4.2.27, and 12x 1TB drives in X-RAID2. From what I understand this NAS only supports up to 2TB drives in all bays (that said I *believe* 1-4 ...
- Jun 09, 2017
Yes, they are compatible. WD even suggests them for NASes up to 16 bays, You will get 18TB with a 12 drive volume with dual redundancy RAID6 (XRAID or not) or with 2 x 6 drive Raid 5 volumes. If you are running RAIDiator 4.2.x, you cannot grow the volume to that size, you have to factory default with the drives in place. For that reason, you may want to consider updating to OS6, for which you also need to factory default. With OS6, you could later upgrade the first 4 drives to grow an XRAID volume.
Sandshark
Jun 09, 2017Sensei
- bachtechJun 12, 2017Aspirant
Great, thanks for the info!
