Coke01
Jul 04, 2014Aspirant
WD Red SATA 6Gb/s 64MB 3.5" Hard Drives
Hi all, I have ReadyNAS NV+ configured X-RAID with 4 x Seagate 1 TB Barracuda's ES.2. RAIDiator 4.1.13. Device has been running 24/7 for many years without fault, until now. More recently SMART err...
Jul 05, 2014Guru - Experienced User
If you go 3x2TB you will need to do a factory reset (and rebuild your data from backup). The reset is probably needed anyway to get 4K sector alignment.
