dhinesh
Aug 01, 2013Aspirant
WD RED WD30EFRX
The WD RED WD30EFRX 3 TB hard disk is on the list of compatible hardware for the readynas pro business edition (6 bay). Whats confusing me is that this hard disk is approved by Netgear whereas the Wes...
Aug 03, 2013Guru - Experienced User
If lifeguard fails with bad sectors, I would trust it (USB or SATA).
Try to exchange the bad ones with the seller, as they will give you new disks. WDC will give you recertified.
