dat4wd
May 10, 2009Aspirant
WD2002FYPS - 2TB
Just upgraded from original Seagate 1Tb to brand new Western Digital 2Tb WD2002FYPS in a ReadyNAS 1100. All right! /Dat4WD
dat4wd
Jul 15, 2009Aspirant
Muxje wrote:
Число циклов перемещения блока магнитных головок в рабочее положение. 200002
If my poor grasp of Russian is correct, this is the load cycle count. That is a rather high and unusual number, for only 1850 hours of uptime. Others have stated that these drives are rated for up to 300.000 load cycles, but I don't really know if that is accurate, and what happens if the drive exceeds this number.
In comparison, my old WDC drive shows over 8500 hours of uptime, and has had only 1900 load cycles.
Yes! You right. I havn't any idea how to fix it. What do you think - wich side is responsibility for this issue - Netgear or WD?
