dat4wd
May 10, 2009Aspirant
WD2002FYPS - 2TB
Just upgraded from original Seagate 1Tb to brand new Western Digital 2Tb WD2002FYPS in a ReadyNAS 1100. All right! /Dat4WD
davec1
Jul 17, 2009Aspirant
Muxje wrote:
dat4wd wrote:
Muxje wrote: WDC make a tool called WDIdle3.exe with which you can turn off the Green sleep feature (Google for the tool, it's not on the WDC site).
Which command line parameters you use? Show me your command line, please.
I used:
wdidle3 /d
This disables idle3 mode completely. See also the thread I posted a link to earlier (page 15)
If either the Readynas or the disk's firmware is fixed so the two work correctly together, the same tool can be used to re-enable the Green idle3 mode.
@muxje - Do I need to attached the hard drive through a SATA interface to use wdidle. Or can I use a USB enclosure (which would be much easier).
Also, what version of wdidle3 are you using - I can only find version 1.0 for download.
Thanks
