dat4wd
May 10, 2009Aspirant
WD2002FYPS - 2TB
Just upgraded from original Seagate 1Tb to brand new Western Digital 2Tb WD2002FYPS in a ReadyNAS 1100. All right! /Dat4WD
infrant_delta
Aug 06, 2009Aspirant
Quicker wrote: First, according to WD support site, they upgraded WD1000FYPS firmware so that idle 3 timer was increased to 5 minutes. Why on earth they didn't apply that to WD2002FYPS as well?
Hmmm... It could be that the firmware in my drives are "old". It would be interesting to see which version you get when you unpack your drives.
Quicker wrote: Secondly, standard Linux system syncs filesystems every 30 seconds. Therefore there shouldn't be any difference in your setup. You should still encounter 120 LCC per hour whilst idling. Unless you have tweaked your system's sync timer to less than 24.5 sec. Or wdildle3 actually disables IntelliPark in RE4-GP.
I think it's probably a question the Jedi can answer as far as manufacturer tweaks. I haven't applied any system tweaks, except for actively disabling services that are not required in my environment (Apple Bonjour services, UPNP, etc)
It could be possible that there are other ReadyNAS services (X-RAID2?) that actively access the drives between > 12.8 and < 25.4 seconds.
