vanguide
Feb 18, 2011Aspirant
WD2003FYYS RE4 - 2.0TB
Hello, I was thinking of buying 4 of these WD2003FYYS disks for my NVX. But they are not listed in the official NVX Hcl. On the other hand when i take a look in the HCL of the NVX pioneer edition,...
mdgm-ntgr
Feb 18, 2011NETGEAR Employee Retired
That is weird.
Both the NVX and NVX Pioneer have the same hardware so I think they *should* work. However if you have issues support may be unable to help so long as it's not listed for your ReadyNAS model.
