vanguide
Feb 18, 2011Aspirant
WD2003FYYS RE4 - 2.0TB
Hello, I was thinking of buying 4 of these WD2003FYYS disks for my NVX. But they are not listed in the official NVX Hcl. On the other hand when i take a look in the HCL of the NVX pioneer edition,...
RobVSF
Jun 05, 2012Aspirant
Interesting. We are using four WDC RE4 WD2003FYYS disks in our ReadyNAS NVX Business Edition using X-RAID2. Frontview is saying each disk is running at either 40 C (104 F) or 42C (107 F). The system fan is running at 2109 RPM and system temp is 42 C (107 F), which is right in the middle of normal. However, our ReadyNAS is in a chilled storage room. If you have the funds, you might want to try placing your ReadyNAS Duo in a cooler part of the house, like a basement or concrete area, then using a Powerline system (more reliable than wireless) to connect it back to your router.
