Caustic
Jul 16, 2012Aspirant
WD30EFRX 3TB "Red Series"
Has anyone tried any of the RED series? I am looking to get the 3TB model for an NV+ v2. It is listed as compatible, but has anyone tried it themselves? Thanks.
mdgm-ntgr
Jul 16, 2012NETGEAR Employee Retired
Are you sure you have the NV+ v2? The NV+ v2 is charcoal in colour whereas the v1 is silver. 3TB disks are not compatible with the v1. See How to tell whether I have a Duo v1 or Duo v2 or NV+ v1 or NV+ v2
Looking at your earlier posts and forum join date it sounds like you have the v1 not the v2.
