heymen
Oct 21, 2013Aspirant
WD40EFRX WD Red 4tb For ReadyNAS104?
Hi Guys, i know the new 4tb red WD40EFRX is pretty "new" to the market. Has anyone tried one of these on the netgear readynas 104? i'm thinking to get one these..
cbgifford
Oct 25, 2013Aspirant
, load count is 83402 on drive 1, 76748 on drive 2, 82595 on drive 3, power on hours 553.
StephenB wrote: Have you checked the load cycle count?
Load Cycle Count; Load/Unload Cycle Count S.M.A.R.T. parameter indicates the number of cycles into Landing Zone position. \\
Comes out to about three times a minute. That's ridiculous. Trouble is, some operating systems regularly write something onto the hdd causing a few load/unload cycles a minute (typical Linux example: /var/log/*) :(
I just ran S.M.A.R.T. across an old WD Blue 320gb hard drive that I am using for a swap drive in a Windows 7 box. Power on hours 25302, Load Cycle Count 15629. Seems that OS6 Linux based OS could stand a tweak or two not to write so much to the hard drive or Netgear could support the drive and tweak the power management setting for the drive if they decide to support it. Unless someone out there now knows how to do that on OS6?
In the mean time for the original post, do not buy them...and thanks StephanB for pointing me in the direction of saving my hard drives. I am shutting the 314 down until either I swap out for ECL hard drives or Netgear decides to support them. Or I can figure out how to change the power management options for the drives
