heymen
Oct 21, 2013Aspirant
WD40EFRX WD Red 4tb For ReadyNAS104?
Hi Guys,
i know the new 4tb red WD40EFRX is pretty "new" to the market.
Has anyone tried one of these on the netgear readynas 104? i'm thinking to get one these..
- benjamins_2002Aspirantxeltros and StephenB,
Thanks for the great information; you've helped me clear some things up immensely. - StephenBGuru - Experienced UserAs you can see, the WD40EFRX is not on the HCL for the ultra (http://kb.netgear.com/app/answers/detai ... hard-disks).
It is on the HCL for the RN104. Since this thread is about WD40EFRX for the RN104, you really shouldn't have posted your question on this thread - you should have started a new one, and included the NAS you particularly were interested in.
Using a drive that is not on the HCL will result in Netgear denying support. Understandable in a way, but often very annoying since they don't update the HCL on legacy units very often, essentially leaving you little choice.
The drive will work in the ultra, and the head parking threshold issue discussed above is not a problem with currently manufactured WDC Red Drives. There are limits to expansion, so that is worth discussing on a separate thread. I suggest you start one, and identify the current disk configuration and your firmware in the new thread.
Also, if you are using the normal xraid, your storage capacity will not increase until you add a second 4 TB disk. - xeltrosApprenticeI think someone managed to get some seagate 6Tb model recognised. viewtopic.php?f=24&t=77600
So I think 4Tb is safe unless you hit the 4Tb expansion limit or the 16Tb volume limit of older OS. I believe that they have not updated the compatibility list for everything. I think the WD RED WD30EFRX is on the compatibility list, if 6Tb models are recognised and the drive is recognised in another capacity, assuming that the 4Tb model works is reasonable, not certain but reasonable. That said there is still the warranty problem, Netgear can deny support for non-supported drive. - benjamins_2002AspirantI am new to the NAS world. I've got a ReadyNAS Ultra 4 and I am wanting to upgrade at least one of the drives with WD40EFRX WD Red 4TB. According to the "Hard Drive Compatibility List", WD40EFRX is not compatible. Do you see any issues with this? From what I've been reading, some users in the past have experienced some issues with this setup. Does anybody know if this is still an issue or is this something they're still looking into? Thank you very much for any insight you and anybody else may have.
Hard Drive Compatibility List:
http://kb.netgear.com/app/answers/detail/a_id/20641/~/hardware-compatibility-list-hard-disks - StephenBGuru - Experienced User
Is what corrected?benjamins_2002 wrote: Any word if this has officially been corrected yet? - benjamins_2002AspirantAny word if this has officially been corrected yet?
- sguszAspirantI just purchased a WD40EFRX. It's been in my system for almost 2 days now and it looks like my LCC is still at 0. I would have expected it to move at least some. At least it looks like the newer ones shipping don't have the issue.
Model: WDC WD40EFRX-68WT0N0
Firmware: 80.00A80
SMART Attribute
Raw Read Error Rate 0
Spin Up Time 0
Start Stop Count 2
Reallocated Sector Count 0
Seek Error Rate 0
Power On Hours 32
Spin Retry Count 0
Calibration Retry Count 0
Power Cycle Count 2
Power-Off Retract Count 1
Load Cycle Count 0
Temperature Celsius 37
Reallocated Event Count 0
Current Pending Sector 0
Offline Uncorrectable 0
UDMA CRC Error Count 0
Multi Zone Error Rate 0
ATA Error Count 0 - immagikmanAspirantThanks a lot, I just recently purchased the drives, hopefully they have the issue adjusted.
It's listed on the hcl (http://kb.netgear.com/app/answers/detail/a_id/20641). Early purchasers found an issue with load cycle count increasing, but some recent posters indicate that WDC has adjusted the thresholds in more recent models.immagikman wrote: Been several months now since the last report, any new word?
WDC has also released a new utility to adjust the head parking threshold (replacing the old wdidle). So even if you purchased a model that had the LCC issue, you can fix it (assuming you can connect the drive to a PC). - immagikmanAspirantBeen several months now since the last report, any new word?
