TallDavid
Oct 17, 2014Initiate
WD60EFRX WD Red 6TB For ReadyNAS104?
Fry's has started offering the WD 6TB Network NAS HDD SATA 6Gb/s 64MB Cache for $239. I know this new drive is not on the official compatibility list. Will the RN104 support 6TB drives? If so, how...
mdgm-ntgr
Oct 17, 2014NETGEAR Employee Retired
Volumes > 16TB won't work on the 104 so this does limit what RAID levels you could use.
If you use drives outside the compatibility list and run into issues then support may refuse to help.
So if you use 6TB disks it is even more important than otherwise that you make sure that you backup your data regularly
Welcome to the forum!
